Thread: Cat 60 rod journal diameter?
    Mar 2007
    Martin SD
    27
    Default Cat 60 rod journal diameter?
    Does anyone know what the standard rod journal diameter is or was . Mine is in pretty tough shape and will need to be ground . the least worn spots measure about 3.450 was this standard ? or is it already .050 under from 3.5". thanks Paul
    7,048
    ???? I answered your question in the for sale section.
