Results 1 to 10 of 13
Thread: Cat Power Unit 4D1060
    19
    Default Cat Power Unit 4D1060
    I have this engine that is from a Cat 44 pull type grader and it runs!! It is a single cyl. gas engine with a magneto and is air cooled. Its a heavy beast as it weighs 325 lbs.
    Does anyone have one of these out there anywhere? Is it rare? I'll try and post a picture or 2 of it.
    19
    Default pic of engine
    see attachment:
    I have a better pic but this site asked me to reduce it to 800 x 1200 so this is the best I can do on short notice.
    KB
    NW California
    258
    Book shows the 4d---- as a power unit, used on the 66 and 77 grader.
    19
    Default book for engine
    does your book give any specs such as HP, RPM, bore, stroke, etc. ?
    also, anything on a governor, carb settings etc. Where can I find this info if not in your book?
    Thanks!
    portland victoria australia
    866
    Default g800
    hello kellyb ,the motor fitted to the 44 single frame grader in 1937 was the g800.
    bore=3''5/8 stroke= 4'' , hp =5.5 @ 1300 rpm ,sorry this is the only info i have ,hope it helps ,bruce oz
    Colorado
    368
    Default G800 Grader Engine.
    Kellyb,
    Bruce oz, Information is the same as mine. The only thing I would add is at Sn. 4D1196 a further refinement had been made to the grader engine which would assist in preventing the entrance of dirt into the engine. A new cylinder assembly had been provided, which could be used on all graders that completely enclose the valve push rods. Hope this is a little more help. Maybe someone will show up with some more information.
    Kelly
    Old Caterpillar Watch Fob.
    Without history, a society shares no common memory of where it has been, of what its core values are, or what decisions in the past account for the present circumstances.
    1,588
    Kellyb, I've been told that the engine is indeed sought after, because it is missing on many of the surviving No. 66 pull graders. GWH
    19
    Default motor for sale?
    to gw75 diesel,
    I may be interested in selling it, yes, would the best way be to post it on this website?
    or ebay it?
    KB
    West Jordan, Utah
    149
    Ebay!!!!!!
    Perth, Western Australia.
    897
    The maintenance instructions for the single cylinder G800 engine (the smallest gas engine built by Cat), are found in the Operation and Maintenance Instructions booklet for the Power-Controlled #66 and #77 pull graders.
    The OMI form number for the Power Controlled #66 grader, S/N 5E1-up, is 3226 .. and form number for the P.C. #77 grader, 9C1-up is 1663.
  1. Cat power unit
    By moparman in forum DISCUSSION
    Last Post: 01-23-2010, 07:05 AM
  2. Cat 40 Control Power Unit
    By mvoth in forum DISCUSSION
    Last Post: 10-06-2009, 06:52 PM
  3. Cat Power unit 7S
    By mkreh23 in forum DISCUSSION
    Last Post: 09-30-2009, 08:33 AM
  4. Cat d4400 power unit
    By SpragueM in forum DISCUSSION
    Last Post: 07-23-2008, 09:27 PM
  5. Cat Power Unit question
    Last Post: 11-27-2007, 05:17 PM
