Results 1 to 1 of 1
Thread: Welcome JoePrue66
    victoria australia
    1,181
    Default Welcome JoePrue66
    Hi JoePrue66,
    welcome to the BB, good to see you got here OK.
    Lots of info and experience here to help you with your D13000 engine dilemma.
    I left you a PM over on Smokstak about compression figures for the successor to the D13000 , namely the D342. It should be a good guide as the later D13000 pistons, cylinder liners, conrods, etc, are the same for both series of engine.
    Hope this helps.
    Attached -- is a scan of the Cat data on compression testing the named series of engines. I came across this in a rubbish bin years ago, hence it is somewhat scrunched up.
