Results 1 to 7 of 7
Thread: Eismann CM4 conectors
    Watlington, England
    282
    Default Eismann CM4 conectors
    Does anyone know what the connectors between the spark plug leads and Magneto cap look like for the Eismann CM4 mag ?
    My parts book doesn't show this level of detail.
    My R2 didn't have any plug leads when I bought it, so I will have to make some up.
    John Gaunt - Link Club Treasurer (Formerly ACMOC Chapter 2 Treasurer).
    1941 D7 7M
    1940 D4 7J
    1940 D2 5J
    1940 R2 4J
    Eastern Oregon
    966
    Wouldn't that take the standard male crimp on fitting? It wouldn't be a bad idea to unwind a bit of the copper core after you get it through the fitting and then solder it as well. It seems I've seen that on older (pre 50's) gas engines.
    uk
    149
    John,
    You should be able to get those connector's from any vintage magneto supply
    like Independant Ignition, the connector's you want are like a small brass cup
    with a centre screw.
    Shovel man.
    7,046
    Look like the old standard "clamshell type" to me.
    Watlington, England
    282
    Quote Originally Posted by shovel man View Post
    John,
    Shovel man.
    Thanks, Richard, I'll give them a try.
    1941 D7 7M
    1940 D4 7J
    1940 D2 5J
    1940 R2 4J
    CATLAND
    335
    I use the spec as listed in my eisemann manual / Cat Serivemans data, OM I have the same as you, the clamshell type the one with the one or two prongs which press throu into the core, and grip the cable, and shove into the mag cap hole ..I think shovel man is referring to the Brass Knulled ring thant sit's on the spark plug thread end the Posh Spark Plug to Lead Fixxing, as against the modern tube type fix
    The Modern Plug Leads from a Fiat (I forgot the Model) Actually Fits a R2, Perfect in Length and in Racing Yellow,and with Surrpressors, so you can still hear the Radio/Wireless when on machine,,
    John any old classic car electric guy should be able to help you out, or an Auto Electrican Local to you..
    CM
    7,046
    Hi Catman,
    You don't want to be using the surpressor type leads with a magneto...tough on magneto operation....get the solid core copper type 7mm wire.
