Results 1 to 10 of 15
Thread: A load a little high and wide but saved from the scraper!
    ILL
    110
    Default A load a little high and wide but saved from the scraper!
    Went and did some Wisconson picking over the weekend with Bob S. What do you think the G.V.W is on this load?
    Feb 2009
    ontario canada
    87
    you look like us farmers fron ontario we dont haul a half a load but i will admit i do nkow what roads to take to go around the scales. But i must admit you were creative in placeing that load .
    Sep 2009
    Gilroy, CA
    355
    You look like Catman's equipment broker.
    CATLAND
    335
    Bob, Looks Fine from here ref: Tin Can, The only problem I can see, is the Crank Handle on the 2 Ton, Needs to be removed !!!,, Otherwise, Looks Pretty Good. I recon you are getting the hang of loading
    Snr Catman is at my side and he has decided the best method of unloading the Container you just loaded up.. Is to Gas Axe the sides out, Save the Cats but Scrap the Box
    Byron
    453
    Default Picking in what state?
    MIke you were picking in ILL. Did Bob get the Radiator and shroud that was with the Frame?
    ILL
    110
    Your right Terry. But the guy I was with was from Wisconsin. Not sure if he got that or not. Might have been the load I did not go with. Mike
    Pittsburgh,PA
    310
    Is that 28 a side seat tractor? Sort a looks like from the picture.
    CATLAND
    335
    Mike the 28 looks good, deal done with bob, Its on the Catman's Pile, mike can you email photo's to me, I would really like to built back to life your cat 28 tailseat wide
    Catman
    453
    Default Side seat or not side seat.
    The 28 is not a side seat, but may have been one at one time. The seat on it has been modified. The engine is free and does turn over.
    Bryon if you got the 28 it will be less work than the 50 you were interested in. That machine is sold either to one of two buyers.
    Terry
    453
    Mike he had my son with him when he picked up his plow and other chassis on Friday night.
    Terry
