Results 1 to 9 of 9
Thread: Pony motor compression
    Houston, Texas
    60
    Default Pony motor compression
    I just got my RD4 last Thursday. The pony motor does not seam to have any comrpession. Can someone tell me what the compression should be on a 1937 Rd4 s/n 4g4344 should be. Thank You
    7,112
    There doesn't seem to be any specs on pony motor compression. They seem to work as low as 40 psi (tired) with new maybe getting 90 -100 psi. If compression is really low, valves are usually the problem (mostly stuck from rust or carboned up) or stuck rings or just plain wore out. If you are running a compression check be sure to have the throttle wide open and squirt some oil through the plug holes to help with sealing the rings.
    Houston, Texas
    60
    Default Rabbit2
    Thanks for the info, I've ordered a operators manual and have not got it yet. I have a 4 1/4x4 Cylinder engine service manual. I looked and could not find compression info anywhere. When I turn the pony motor over by hand you can hear is hissss but didn't seam to have much compression. I'll do like you said and squart some oil in the cyclinders and check it again. Thank you again. Lou Ray
    7,112
    You won't get much out of the pony just rolling over the flywheel by hand. Takes at least 2-4 power strokes cranking the pony starter or brisk pulls with the rope while capturing the compression gage pressure to get anything meaningful.
    Houston, Texas
    60
    Default Rabbit 2
    Thanks again for the info. I'll sure take your advice and use as long a rope as I can to get as many "wraps" as I can on the pulley so I can get as many power strokes as I can to try and get a good check. I'll take some wd-40 and pull the plugs and see if I can spray the valves in case they may be stuck. Then after its set for a while I'll put a couple squarts of oil in the cylinders and see what I get for compression. Thanks again.
    RABBIT2
    Oakland City, Indiana
    23
    Default pony compression
    We have had the bores to become egg shaped and had them reground to circular and used 060 over pistons. It made a different pony motor out of the tired one.
    191
    And in all the excitement, don't overlook the obvious and leave the cylinder drains open!
    hope this helps, alan627b
    Houston, Texas
    60
    Default Rabbit 2
    Dave & Alan627b Thanks for the info. I'll sure keep it in mind and put it to good use.
    Brimfield, IL
    50
    Default Pony compression
    Rabbit,
    I've been playing with the same problem on my D4, compression on one but not the other. Instead of pulling on the rope, use an old electric motor. Mount it on a 3' 2x6 and use a belt about 70" long to spin the pony over. Takes a lot of pulling out of the equation.
    Had an old buddy of mine that permanently mounted an electric motor on his D4 to start it. Pretty good idea.
    Sam
    Sam Meeker
    Brimfield, IL (W of Peoria)
    Twenty Orchard 8c48, Forty Diesel 3G318
    D2 5J1, 5U13731, 5U16630
    D4 7u3830
    D7 64A
    12 8t7189, 212 9t3023
    933's 11a2326, 11a2352
    236 4yz04449, 242B BXM1807
    613 71m3201
    MT765
  1. RD-6/D6 pony motor help
    Last Post: 07-08-2011, 08:01 PM
  2. D2 pony compression
    By Todd in forum DISCUSSION
    Last Post: 04-10-2010, 12:19 PM
  3. pony motor,D2 5J
    By D2Dave in forum DISCUSSION
    Last Post: 10-23-2009, 08:31 AM
  4. D2 4U Pony Motor
    By R4pat in forum DISCUSSION
    Last Post: 02-24-2009, 06:22 AM
  5. D4 Pony Motor
    By ol_coyote in forum DISCUSSION
    Last Post: 06-28-2008, 03:22 PM
