Results 1 to 7 of 7
Thread: 12 volt glow plugs
    Dec 2010
    2
    Default 12 volt glow plugs
    anybody found a 12 volt glow plug to fit the 1S1970 pre combustion chamber?
    7,112
    No such thing that I'm aware of.
    1,821
    Apply 12 volts to the 24 volt plugs and you will get 1/4 of the heat output, but they will still heat as long as you don't have any 24 volt relays etc. They won't work.
    Nov 2007
    NW Ohio
    511
    Default Glow Plugs
    Cat offered 12V Plugs
    155 Watt part# 4S7812
    120 Watt part# 3S9612
    7,112
    Do you know if they fit/replace the 3H2033 glow plugs in the 1S1907 pre-com chambers?
    Nov 2007
    NW Ohio
    511
    Default Glow Plugs
    No not sure.
    Chillicothe, IL
    211
    My D311H gen set engine (51B) was offered as both 12V and 24V starting.
    For 12V starting, glow plugs 9M6055 (early) and 4S7812 (late) were used.
    For 24V starting, glow plugs 9M5708 (early) and 4S7824 (late) were used.
    They all use chamber assembly 2M8590.
    I believe these glow plugs are different dimensions than 3H2033.
