L 20 Serial No's Position .
Could somone be able to tell where I can Find serial no's stamped on a big twenty . Plate on Rear is Missing , and have sratched around and can't locate any . any help much appreciated LJ
Hello, look on the top of the transmission case under the seat, tou may have to remove seat to see it. Also look on the engine block where the pushrods for number 4 clylinder come up its stamped there on my PL series 20's. Caterpillarman
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
