Thread: D2 stuck pistons
    Feb 2011
    Israel
    60
    Default D2 stuck pistons
    This time the pistons stuck
    Crankshaft was stuck half-turn
    Stuck gearbox
    Tractor abandoned for over 30 years
    The engine was filled with rain water
    oil floating on the water
    motor parts remain lubricated
    Although it was all full of water
    The target is 2 sleeved 2 pistons for another tractor
    Itzik
    Unfortunately photos do not in the right order
    Mar 2011
    BC Canada
    75
    Thanks for the pictures, you have your work cut out there, l guess with that rain your a little north of the Negev!
    That is some serious crud that settled in the bottom.
    Dont forget the pictures of the one youve fixed
    cheers
