Thread: #41 hydraulic pump for a 1952 Cat D2
    Suisun Ca.
    87
    Question #41 hydraulic pump for a 1952 Cat D2
    When your checking the fluid in your hydraulic system and your Cat has a
    #41 hydraulic pump on it. Where should the level be when you open the cap? This particular pump has a screen in it when you look down the neck. Checking the book does not seem to give any clues?
    thanks,
    Mike
    7,110
    Just says oil should be visable in the filler neck.
