Results 1 to 10 of 19
Thread: trouble accessing forum
    Avon, Ms 38723 USA
    168
    Default trouble accessing forum
    When I access this site--------I get a window showing that part of the data may not be delivered clean (may be contaminated)----------do I want to access only the part that is determined to be clean-----or not.
    When I click on "yes" to access only the safe information-----------I am not able to pull up the formatted part of the ACMOC site----------looks like I am pulling up a skeletal outline of the site.
    The only way I gain access to the full format is to click on "No" in regards to accessing only the safe content.
    Is this something coming from the ACMOC site-----------or possibly something else in regards to my computer. Only site I pick this window up on is ACMOC.
    Helllllllpppppppp?????? I definitely don't feel comfortable clicking on the acceptance of possibly contaminated data----------I create enough computer problems on my own.
    Delta Dirt
    Delta Dirt
    Avon, Ms 38723
    D2 5U and other scrap iron
    I'm getting the same also.....just started recently in about the last week or so.
    Apr 2009
    Prather, CA
    140
    I'm having the same problem, it started last Wednesday for me. If I log out and then back in it clears up for just that one instance. As soon as I navigate away and then back again the problem reoccurs.
    Scott
    1928 CAT 20, 1943 D42T - Military, 1942 Athey ForgeTrak - Military, 1975 951C, 1957 Oliver DDH
    Chicago
    978
    I've been away from the computer since yesterday morn. I will forward the info to Megan and see what she finds. Sorry fellas.
    Eastern Oregon
    965
    If you're using Firefox for a browser, you might try going to Tools at the top of the page, click on Options and check the box that says "Block popups". There's a similar setup in the IE browser.
    Sep 2008
    Peoria, IL
    58
    Hi all,
    Check the URL and see if it says HTTPS instead of HTTP. We recently adjusted the main site to use HTTPS (secure) login to better protect your user details. The BB doesn't force you to use HTTPS, but if you got here from the main site, it may come up that way.
    Internet Explorer has an annoying pop-up box that alerts you that some of the content may not have been delivered securely. This has to do with the way the BB is pulling in files like images and styling. It doesn't necessarily mean there's a security problem.
    Two ways to fix it:
    1) Change the HTTPS to HTTP when you're on the BB
    2) In IE, go to Tools -> Internet Options -> Security tab and click the button for Custom Level. Scroll a little over midway down through all the options and look for one that says "Display Mixed Content". Change it so it's "Enable" instead of "Prompt".
    Bulletin board problems? Email your questions to support@acmoc.org
    (...I can't tell a tractor from a lawnmower, so we're even.)
    Avon, Ms 38723 USA
    168
    adco:
    Re: check the URL for HTTPS vs. HTTP
    How do I find URL????
    I am probably more computer illiterate than you are with the tractors and lawnmowers--------Is there any problem/dangers with clicking "No" on the pop up window and continuing forward???
    Thanks for your help in advance.
    Delta Dirt
    Delta Dirt
    Avon, Ms 38723
    Hi Delta Dirt,
    Went through the drill as recommended and it took care of the problem....which should not have been a problem in the first place.
    The URL is the site name in the box at the very top of the page.
    Oct 2007
    Dorr, MI
    120
    Adco,
    I'm experiencing the same issue and checked my settings under the Tools drop down and mine were already set to enable so that doesn't appear to be the fix in this case. Hopefully somebody comes up with a fix, it's not a big issue just an annoyance. Thanks.
    Bryan
    Chicago
    978
    Bryan,
    Send me a PM with the exact description of what happened when you attempt to log in. Thanks.
