how do you adjust the clutch on a 22... i just replaced it with a new one and now need to adjust it...
You only need two tools in life -- WD-40 and duct tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape!
Hi LCM,
scanned below is the proceedure from the "Operators Instruction Book" Form No SENR5080 ( replaces form No 2126)
Copy it to your 'puter for the future.
