Results 1 to 2 of 2
Thread: 22 clutch adjustment
    Jul 2011
    Kennewick, WA
    444
    Default 22 clutch adjustment
    how do you adjust the clutch on a 22... i just replaced it with a new one and now need to adjust it...
    You only need two tools in life -- WD-40 and duct tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape!
    victoria australia
    1,178
    Default 22 Clutch And Brake Adjustment.
    Hi LCM,
    scanned below is the proceedure from the "Operators Instruction Book" Form No SENR5080 ( replaces form No 2126)
    Copy it to your 'puter for the future.
