Thread: CAT 22 lubrication question
    Apr 2011
    Watervliet, NY 12189
    261
    Confused CAT 22 lubrication question
    I recently acquired a CAT 22 and am reviewing the lube chart. It says to fill the engine fan bearing every 10 hours with semi-fluid lubricant. Can someone tell me exactly what that is?
    Elkhorn, WI
    1,635
    Default Semi-Fluid Lubricant
    Should be the same stuff the chart says to put in the track rollers. Most guys probably put grease in it.
