Results 1 to 10 of 12
Thread: Looking for some spares: D7E 48A-series
    Somerset West, near Cape Town South Africa
    89
    Default Looking for some spares: D7E 48A-series
    Hi guys,
    We're looking for a set of contacts (points) & condenser for the starting engine on a D7E 48-series.
    Bear in mind that we're located in South Africa.
    Local CAT agents non-compriendo regarding availability
    Somerset West, Cape Town
    South Africa
    89
    Hi all,
    Could somebody please forward me the part #'s for a set of points and condenser for the starting engine on a D7E 48A series.
    South Africa
    Default Magneto parts
    THYS. been looking at the 48A microfisc and they don't list separate parts only magneto overhaul kits unfortuatley these are all dicontinued (no longer available) but it does say in the NPR refer to service magazine dated
    07 August 1989. Sorry but I do not have these maybe your cat dealer has them!! Not much help i'me afraid but I did try. Al
    7,055
    Not all that easy
    From the 48A1- up parts book the mag is a Cat #7M4700
    The condenser is a Cat #2M2757
    The points are only offered in the Cat #7M7859 overhaul kit (which includes condenser).
    This is a Wico magneto and to get to the individual parts the Cat to Wico equivalent conversion number is required (I don't have) then approach source for Wico magneto parts.
    This might get you closer:
    From the 47A3396-up parts book:
    The mag shown is a Cat #3S2987 which crosses to a Wico # XH2823S
    Uses the same #7M7859 overhaul kit.
    Hope this helps
    148
    You might try checking with www.standardmagneto.com they are located in Chicago,USA...... if anyone has those parts,they would. Good Luck
    NW California
    250
    For 48a1-up,
    Magneto assembly, 7m4700,
    Contact kit is 7m7860, wico # is:k12770
    Over haul kit is7m7859, wico# k12771
    Condenser is 2m2757, wico # x6916
    7,055
    All right josh I take it you are in possession of some Wico info. I'll refer to you next time
    7,055
    Hi Josh,
    On further checking a little help required
    The "contact" kit 7M760 list includes cam wiper felt, contact group and screw assembly.
    The "overhaul" kit list includes gasket, oil seal, bearing, oil slinger, carbon & and spring group, ground connection group, breaker contact group, condenser group and screw assembly.
    Is the "contact group & screw assembly" the same as the "breaker contact group"?????
    Maybe the Wico version would clarify. Thanks
    NW California
    250
    Hi OM,
    Sorry to say but my information does not have a break down of what is in the "kits"
    My numerical parts record has a cross reference section of part numbers from Caterpillar suppliers to Cat and visa-versa,
    I seem to be able to cross most of the suppliers part numbers on our "classic" tractors,
    Josh
    Jun 2007
    SW Oklahoma
    22
    dewets; sorry i can't help You on Your needed info;bcwayne thank's for posting that address. I believe they are going to help with one of my mags thanks for the info. Dewets i hope someone can help You with the info that You need. mlg
  1. 48A Egnine oil filter
    By poor farmer/logger in forum DISCUSSION
    Last Post: 01-18-2010, 07:44 AM
  2. D2 U series & J series compatiability
    By mcarp in forum DISCUSSION
    Last Post: 10-16-2009, 08:19 PM
  3. Transfer Pump is the D2J series same as U series
    By novavalleycat in forum DISCUSSION
    Last Post: 07-18-2008, 07:12 PM
  4. 6U series D4
    By subsoiler in forum DISCUSSION
    Last Post: 07-25-2007, 02:47 PM
