Results 1 to 8 of 8
Thread: D8 8R part number needed
    netherlands
    114
    Default D8 8R part number needed
    Hello , i have a D8 8R military tractotr and i have no parts book yet .
    I wanted to drain the radiator , but the drainplug was not movimg at all .
    Have welded some nut on top , but still nothing .
    i ended up in drilling the plug out and also drilled the bronze part out .
    I needed to replace this drain plug from the radiator bottom tank and the bronze part where the plug goes in .
    Who could help ?
    Thank you , Gilbert
    563
    Here a pic from the tractor.
    oregon
    151
    nice tractor. is that the one on youtube.
    3B8031
    oregon
    151
    3B8031 they call a plug. that looks to be the screw you turn to drain.
    3B8033 they call a bushing.
    6F7061 they call a dowel.
    these last two part numbers are part of assembly 1F3000.
    7,112
    They used the same pieces on the "U" model D4's and possibly others.
    Should not be a problem to replace......maybe.
    netherlands
    114
    Default Thank you
    Hello u-joint and Old Magnet, thank you for the info .
    Have asked the dealer today , but these parts numbers are discontinued ?
    Will see if i can pull a bushing ( bronse ) out of a used bottom tank .
    Thanks again , you are always very helpfull .
    Gilbert
    7,112
    Try Florin Tractor, they list 38 #3B8031 and one 3B8033.
    563
    Tanks everything OKAY !!!!!!
