Originally Posted by
funflyer26
I have recently acquired a 1953 D7 (D7-7M1629SP) and after the first day of using it, the front gear box running the cable drum started leaking oil which got the pads oily and now it doesn't have the friction to hold the blade up. I obviously need to pull it apart fix the seal, clean the pads and then it should work again but I have hit a roadblock in the disassembly process. I have the operation and maintenance instructions, the servicemen's reference book, and the parts book but they are all for the base tractor itself, nothing for the attachment. I have attached some pictures, including what I think is the serial number on the gear box, does anyone know the next step to taking this thing apart? Thanks!
