Thread: Part Numbers for A D-6 5R
    Saint Robert, MO 65584
    44
    Default Part Numbers for A D-6 5R
    Anyone with a parts book for a D-6 5-R that could give me some part numbers would be appreciated. This will be the 4 1/4 inch bore 4600 motor. I have a parts book bought off E-bay, but the seller had a problem with the Post Office. Been waiting almost two weeks to get a book from Ohio to Missouri. Anyway, I need numbers for the oil pan gasket, valve cover gaskets (2 ea), head gaskets (2 ea), and the two water inlet gaskets. One of the water inlet gaskets is the one on the left side of the heads for the fitting that goes to the pony motor and the other is the water inlet on the front of the head that connects the thermostat housing. I'm sure no one else has the problem of having to order things before the funds allocated for them get used for something else. I can order on line from the local cat dealer but I need the part numbers to be able to do it. Thanks
    7,113
    Pan gasket RH 4B327, LH 4B328
    Valve cover gasket (2) 4B291
    Head gasket (2) 8B313
    Thermostat housing to head gasket 2A3599
    Pony water line connection at head gasket 6B145
    44
    Default Part numbers
    Thanks Old Magnet for the numbers. Got my parts ordered.
  1. Cat 22 part numbers
    By R4pat in forum DISCUSSION
    Last Post: 03-14-2010, 08:08 PM
  2. part numbers please
    By kiwicats in forum DISCUSSION
    Last Post: 02-19-2010, 08:30 AM
  3. Need Part Numbers
    By Frank L. Gross in forum DISCUSSION
    Last Post: 06-22-2009, 12:49 AM
  4. D2 part numbers
    By Andy.s in forum DISCUSSION
    Last Post: 06-15-2007, 09:33 PM
  5. Part Numbers For D2/3J
    By Dozerman51 in forum DISCUSSION
    Last Post: 12-19-2006, 08:43 PM
