Thread: Caterpillar 60 Leaning Wheel Grader
    Dec 2011
    3
    Confused Caterpillar 60 Leaning Wheel Grader
    What a great site!!! Several yrs ago I was able to buy an old Cat 60 Leaning Wheel Grader that I played on as a boy in the 50s & 60s. The grader did not move an inch in 45 yrs or so. After I retired from the army in 87 it took me 15 yrs and some luck to buy it. It is in fantastic 100% complete condition.
    Looking for information? how many built? weight? I think the original paint was gray. It has the
    "CATERPILLAR 60 LEANING WHEEL GRADER" on the side in wavy script.
    portland victoria australia
    866
    Default sixty
    hello sfcidaho ,your grader should have a serial number starting with 2A1 - ? built from 1929-31 ,sorry cannot find how many were built ,weigth should be 11440 pounds for the hand operated and 12170 pounds for power control units ,bruce oz
    Liberty, NC.
    1,685
    http://www.chriscomachinery.com/PullGraders.htm
    I do not have much info posted, it is still a work in progress
    Caterpillar No 60
    Series: 2A-1 to 2A-707
    Sixty(L.W.H.C.) 2A1 weight 11300 lbs.
    Erik Christenbury
