Does anyone know of a new source for Ten clutch disc. General Gear does not furnish unit that old.
thanks Gene
thanks Gene
Why don't you just get your old one relined.I'm sure if you went to a speed shop or your local NAPA store they would be able to point you where to go in your area.Good luck
Thanks That would be easy solution.
Gene
If you are going to reline the old disc make sure the splines are in good shape, if there is much wear on the shaft and internal of the disc your clutch will not release as nice as it should. I may have a good used one if you are interested 25 dollars plus the shipping . Ron Meeder
