I think I finally got the right number off of my D2 Generator.
It's a Delco-Remy # 1102425
Any information on watts, amps, etc. would be appreciated.
D2 5U4354.
Scott
D2 5U4354.
Scott
1102425 is a 6v 18amp unit to be used with a 1118332 regulator. This unit was originally for the D4,D6.
The D2 version is a 1102735 with 1118872 or D614 regulator and uses the 1910966 Shock Mounting Package.
The Cat # is 4L0089 (for the 1102425)
sr440
Thanks to Old Magnet and others I had the same generator system repaired and it is running perfectly. Fortunatly I found a Cat oEM regulator and the shock mount kit. The generator I had fixed at a local shop for $75.00. I have a few more pics and I am sure if you did a search you can come up with the thread where these guys guided me through the repair.
Good luck and have a good day............Bill
Thanks OM and Cysco,
It's down being gone through now.
Hope to have electricity all set up next week.
Scott
