Results 1 to 4 of 4
Thread: Dozer Model Plate?
    Jan 2011
    Farmington, New Mexico
    21
    Default Dozer Model Plate?
    Hey guys.
    I have a D4 6U tractor (6U12286). I think it has a 4A dozer blade on it, but not sure. It is hydraulic and looks like some of the pics of the 4A, but has an angle feature that is manually adjusted with pins. Where on the bulldozer is the ID found on these things? Any help is appreciated. Thanks - Bob
    Too many projects... too little time
    I need a winning lottery ticket... anybody...please?
    The ID tag or s/n stamping should be found on the RH side rear of the moldboard (blade) upper part and start with s/n 5F1288-up for that model.
    Jan 2011
    21
    Quote Originally Posted by Old Magnet View Post
    Thanks OM; I'm heading out to the farm Friday, I'll look then. 'preciate it. Is this a 4A? Want to be sure I get the right manual for the blade and hydraulics - Bob
    4A is the correct model....look for the 4A, 4S parts manual Form #30452(1952), a Form #3259(1957) or Form #UEO3259(1967).
