Results 1 to 10 of 14
Thread: Adapter for Grease Fitting on D6 9U Top Carrier Roller
    Leicester, England
    322
    Default Adapter for Grease Fitting on D6 9U Top Carrier Roller
    Does anyone know of where I can obtain an hook on style adapter for my grease gun to fit the 2F1336 grease fitting on the top carrier rollers?
    My local Cat dealer in the UK says they are discontinued.
    Any assistance would be appreciated.
    Regards, David
    1941 D6 5R
    1948 D6 9U
    1948 No 60 1D
    1940's Le Tourneau S3 Rooter
    1970 951A 63K
    Fresno, California
    244
    Default Button Head Grease Can Adapter
    Do you mean this one?
    I have several for sale.
    John
    Titusville, PA
    127
    Feb 2007
    14
    Default Leon
    High pressure grease equipment should not be used on track rollers[per Caterpillar]as extreme pressure may rupture seal material,use volume compressure instead,this pump fills rollers at a relativly low pressure.
    Leicester, England
    322
    John, I have sent you a Private Message regarding the adapter.
    Leon, good point about not blowing out the seals by attempting to pump in too much grease.
    Regards, David
    1941 D6 5R
    1948 D6 9U
    1948 No 60 1D
    1970 951A 63K
    Mar 2012
    Colby, Isle of Man.
    5
    Default grease fitting adapter
    are they the same thing as rollers and idlers etc on an R2? had the same problem trying to get an adapter for mine, priced it up and it was £127 + vat!
    in the end what I did was, bust the top part off, your then left with a hole that can be drilled out and tapped to take a standard 1/8 bsp grease nipple.
    as has been mentioned here, dont go to nuts with the grease gun and blow the seals out! figured it would be better than having no grease at all. realise this solution may be not to everyones liking and not the best thing to do, but it worked fine on mine and as is she is not going to be working 24/7 anymore, thought that was best way around it!
    May 2009
    Australia
    52
    Default these?
    here you go
    giant button head grease adapter
    http://www.ebay.com/itm/Grease-Fitti...#ht_500wt_1314
    Fresno, California
    244
    I can't see a relief valve on the one that McMaster Carr or the one that is on Ebay right now. The relief valve will pop off if the pressure exceeds a few hundred pounds. Normal grease guns exert several thousand pounds of pressure.
    John
    I thought the relief valve model looked like this?
    Sep 2007
    usa
    347
    i thought one was suppose to oil bellows seals by feel? then one would engage the small handle on the compressor the relieve pressure in the hose. anyway this is the way i been doing it. another big thing with buying fittings they come in 3 or 4 differnt threads. be sure u get the right one 4 your hose thread. hope u don't have that alemite weirdo 27 per inch stuff. cost alot more. good luck.
