Results 1 to 6 of 6
Thread: Timeing the magy on my diesel forty pilot motor
    Apr 2012
    Wagga Wagga, NSW Australia
    6
    Default Timeing the magy on my diesel forty pilot motor
    I have recently got the magy fixed on my diesel forty pilot motor and just wondering what's the best way to time it ?
    Lansing,Mi suburbs
    519
    This might not be a lot of help but i helped Dad install the Mag on his Diesel 35, there are 2 options that are 180 Digrees apart, if you get it wrong switch the plug wires. Not a high tech method but youll be able to figure it out
    McBEE, SC
    405
    Wait! the mag isn't the same internally as a D2/D4 mag, if you look at the breaker cam, the points open at 90 deg apart, not 180, so switching the plug wires wouldn't work. It should use a GV-2Q, RC-2Q, or its equal. I think the bosch would be a 4/2-180 ?
    D2 5u
    212 9T
    D4 7J & 7U
    R4 4G
    Diesel 40
    Gas 50's 5A
    Diesel 50 1E1755
    LeTourneau D4 tournapull/Q Carryall
    Letourneau D Carryall's
    LaPlant-Choate CAB-97
    South Carolina
    195
    If the wife hadn't just borrowed my pickup and run off in it, I'd come over and help you. I'd like to see how your collection is coming along anyway.
    Here's the best I can do at the moment.
    http://www.acmoc.org/bb/showthread.p...-on-a-D7/page2
    The Eisemann is an RC-2Q model.
    If it's a Bosch the model is a MJK 4/2 180 C109.
    From the info I have it appears the early D6's, 7's, 8's, D40, D50, D75, D35
    All use the same type (inverted) installation.
    The info I'm posting is for the 9G-D7.
    I'm going by parts book and manual info so please correct if wrong.
    Apr 2012
    6
    Smile magy
    Quote Originally Posted by Old Magnet View Post
    thanks every one for that shes a goer
