Results 1 to 10 of 11
Thread: Cat 2 ton need help/info on engine
    Philadelphia, Pennsylvania
    11
    Default Cat 2 ton need help/info on engine
    I have a really nice 2 ton cat, with original pressed pads, crossbar steering, air cleaner in tact, etc
    it sat for 3 years inside my barn and now the engine is stuck
    I pulled the pan, put some pressure on the crank with a bottle jack and still nothing. looking up inside #2 cylinder, I can see soem rust on the cylinder walls. I filled the cylinders with diesel fuel and will try to soak it out.
    One of my questions is, if I have to pull the head, where can I get a head gasket set? How about piston rings, assuming they are standard.
    thanks for any help
    by the way, what is the approximate value of the machine today, I paid $3500 for it 3 years ago. ( with engine running)
    Dave Newman
    11
    the serial # is 78649
    Napa Valley - Newville CA
    840
    Its 1928 vintage one of the last made they stopped at 78989 you can get rings from Hastings I dont have their info and gaskets from Olsen http://www.olsonsgaskets.com/products.html
    11
    Thanks for the info
    would you have the torque specs for the head bolts?
    also, any idea on value? ( after it is running again)
    Dave
    victoria australia
    1,163
    Default Head torque
    Hi Country,
    no specific tensions are given for these units but the attached should help.
    Cheers, and Welcome to the BB.
    11
    Eddie
    thanks for the info
    I have been a memebr for YEARS- mostly jusk lurking
    see if this looks familiar, as I posted it several years ago
    http://www.easternsurplus.net/images/lesnewman.jpg
    Dave
    Pennsylvania
    281
    dave,
    where in philly are you located? I am from this area too, near norristown.
    11
    I work in Phila near the Tacony Bridge and live in Newtown, Bucks county
    Pennsylvania
    281
    I live over near phoenixville. I am doing a job as we speak in newtown on 413 accross the street from the township building. How many cats do you have?
    11
    catmatt
    I have the 2 ton, D2- 3J I think, a newer D3C hystat, cletracs: F, K20, 35, E-38, OC6-68, OC3, HG-68, John Deere: 2- MC, 450 loader, Lots of hit and miss and a few wheel tractors, plus a pile of army trucks.
    what do you have?
  1. Need info on 2 ton spark plugs
    By brewzer in forum DISCUSSION
    Last Post: 02-14-2010, 05:38 PM
  2. Cat 2 Ton Info n pix
    By §wishy in forum DISCUSSION
    Last Post: 01-22-2010, 10:36 PM
  3. 2 Ton Engine Bolt Torque Values
    By edb in forum DISCUSSION
    Last Post: 10-28-2008, 06:13 PM
  4. Engine Info Search D-334 used in GenSet
    By BobD in forum DISCUSSION
    Last Post: 11-24-2007, 02:31 PM
  5. Need info on 2-ton
    By Rodten in forum DISCUSSION
    Last Post: 01-22-2007, 12:24 PM
