Page 1 of 4 123 ... LastLast
Results 1 to 10 of 37
Thread: Dumb question, No 42 or 44 Hydraulic unit.
    Jan 2009
    Kalamazoo Michigan
    747
    Default Dumb question, No 42 or 44 Hydraulic unit.
    Well, our Plow Day got rained out. AGAIN. Ground was too wet for the "wheel tractor guys" and nobody brought a ground trip plow, only hydraulic plows. I offered to pull the Farmall H and his hydraulic three bottom plow with my D2 just for fun but he wasn't interested.
    I was talking to a guy that said he has a 5J(?) D2 in poor condition that he's going to scrap or part out. He says it has a Cat front-mount two spool hydraulic unit on it (maybe a 42 or 44?) with all of the plumbing and a brush guard. Will a J series pump fit on my U series???
    Rich Salvaggio
    D2 5U9917
    Dec 2008
    Petaluma
    343
    Yes it will goin from j series to U because u take the adaptor brackets off ull also need the drive coupler for the crankshaft pulley but make sure u change ur fan belt before u put it on and if it's a double spool pump more then likely it's a 7w series 44 pump that has a 37gpm pump
    Nothing Like the Smell of DIESEL in the Morning!
    The original "J" installation for "two implements" uses the 8Wxxxx series #44 unit with 2-valve 25gpm pump.
    Same #44 unit as the early "U" models for "two implements" except the mounting group (including drive shaft) changes.
    Same lines group.
    Both utilize a hood mounted surge tank.
    There is a #42 Tool Bar (fits D2/D4)
    There is a #41 Hydraulic Control
    There is no #42 Hydraulic Control
    Jan 2009
    Kalamazoo Michigan
    747
    Thanks OM. When I bought the D2 it came with a toolbar blade but I didn't get any hydraulics. My toolbar blade seems to be an early version, you must detach the arms to reverse them, they don't swing around like other toolbar blades that I've seen. I'll have to dig it out of the weeds and get some pictures of it to post.
    Rich Salvaggio
    D2 5U9917
    With the addition of a few pieces you should be able to get what you want. The same arrangement is listed as "two implements" or with "bulldozer".
    Jan 2009
    Kalamazoo Michigan
    747
    Okay, I stopped and looked at the D2 with the 44 pump today. The pump is rough but looks like it can be saved. Any Idea what a fair price would be? Somewhere just north of scrap value?? Spool valves will need a rebuild and new spools (I am a machinist, we make prototype hydraulic components. I think I can handle that part easy enough). Tractor is serial number 5J6310SP, it's toast and most likely will be scrapped and sent to overseas to come back as a Hyundai.
    Cat 44 pump, Schwinn, Totegote 022.jpgCat 44 pump, Schwinn, Totegote 021.jpgCat 44 pump, Schwinn, Totegote 016.jpgCat 44 pump, Schwinn, Totegote 005.jpgCat 44 pump, Schwinn, Totegote 004.jpgCat 44 pump, Schwinn, Totegote 003.jpgCat 44 pump, Schwinn, Totegote 002.jpg
    BTW, check out the first picture. If you look closely you can see daylight through the front idler. Yikes!
    I'm going to try to buy parts off it (44 unit and all plumbing). Does anybody need J series parts? Exhaust manifold looks useable, Head is gone on main, water jackets cracked on pony, Pony and Main engine REEEEEAAAALY Stuck. Seat tank doesn't look too bad.
    Rich Salvaggio
    D2 5U9917
    Well, it does fit the "two implement" discription.....see if the surge tank exists.
    How do you know the spool valves need rebuilding?
    Get all the parts to the group that you can , what you don't use will make good horse trading material.
    Scrap value is a good place to start......good ones can get close to a grand.
    Jan 2009
    Kalamazoo Michigan
    747
    Quote Originally Posted by Old Magnet View Post
    O.M., One of the spools is rusted and stuck. I'm thinking a pair of new Stainless spools? We have lot's of 303 and 304 SS at work. I didn't see the surge tank but there's one pipe that leads up under the hood on the left side, would that be the pipe to the surge tank?
    The hood is missing as well as the Diesel head. The owner mentioned something about the front guard, he may have that too. The plumbing leads down the right fender and there's two outlets in the center rear, right behind the seat tank. There's also a selector valve (stuck) at the junction block at the crossover pipes near the firewall.
    Cat 44 pump, Schwinn, Totegote 009.jpgCat 44 pump, Schwinn, Totegote 010.jpg
    Rich Salvaggio
    D2 5U9917
    Pittsford NY
    507
    How rare is the 2-spool 44 for the J-series? I'd like one for my 3J.
    Rich, could you please save that radiator grill - mine is toast.
    Neil.
    Neil.
    Jan 2009
    Kalamazoo Michigan
    747
    Neil, do you need the oil cooler grill or the radiator shroud? The shroud is shot but the oil cooler grill may be okay behind the pump.
    Rich Salvaggio
    D2 5U9917
