Results 1 to 4 of 4
Thread: Rd6 pto
    Oct 2011
    Corryong Vic Australia
    90
    Default Rd6 pto
    I am about to fit up rear mounted PTO to my RD6, I have the unit without any control linkages, does anyone have a drawing or picture of what the likages look like so that I can fabricate a lookalike set?
    If you have access to a parts book, in the back in the attachments in the later books there are listed all of the different types of PTOs with control parts. These will give you an idea of how they might go. If you don't find this, email me with your part numbers of the one you have and I may be able to scan a page or two for you.
    Malin Oregon
    135
    Here is a picture of the lever. Jon
    Oct 2011
    90
    Thanks for the photo Jon, it looks the same as one of the levers on the pilot motor for clutch or pinion engagement, will have a look at a parts tractor that I have to see if one of those will do.
