Thread: 955 cat 12a generator
    May 2008
    USA
    72
    Default 955 cat 12a generator
    Can I remove the generator and still run the engine if I put a plate over the hole?
    Yes, you can.
    May 2008
    USA
    72
    thank you
    The reason for the question is that I plan converting it into a drive unit for a alternator.
