Results 1 to 8 of 8
Thread: D2 Idlers
    Oct 2010
    Whitmore, CA
    104
    Default D2 Idlers
    Hi,
    Looking at a set of large diameter idler for a D2.
    The part number on them is 6B8229 which I can't find any reference to.
    Any help is greatly appreciated.
    SCott
    7,048
    6B8229 is replaced by 6B8279
    Oct 2010
    Whitmore, CA
    104
    Hi OM,
    Thanks for the reply.
    Is that the correct large diameter idler for a U series D2 or is it from something else?
    Scott
    7,048
    Sorry, I don't have enough D2 books to check. Might be early "U" but it's not late "U"13237-up. I suspect it's from the "J" series.
    Oct 2010
    Whitmore, CA
    104
    Thank you OM
    Kerrick, Minnesota
    487
    My early D2 "U" series parts book lists the 6B8279 idler to fit tractors 5U1 to 5U6128 for use with the standard length track roller frame, but it would also fit "J" and "U" series machines outside of that range. It is one of the larger 23 1/2" O.D. idlers you're looking for.
    D2 5J2115SP
    D2 5U7066
    D6 2H3072
    No.9 Auto Patrol 8A331
    No.9 Auto Patrol 8A539
    Minneapolis-Moline prototype crawler X253
    1945 Farmall H
    1923 Fordson on Trackson crawler conversion
    Oct 2010
    Banks, OR
    Default Sorry to break into your posts but
    Hello,
    I have a D2 that I need to grease the track rollers on. I seem to find a hard time to get the grease. Do any of you know what kind of grease is used and where I can get it here in Oregon?
    Fred K
    Banks, OR
    long island NY, Hancock Ma
    637
    00 grade grease--most any lubricant dealer can order it--Mine was manufactured by shell
    cat 941B, Cat D2 4U7412, Cat D3B, D4 7U30755
