Results 1 to 3 of 3
Thread: Cat 10 governor arm
    May 2012
    3
    Default Cat 10 governor arm
    The governor arm on my 10 seems dangerously close to the fan blades. The arm is held to location by a keyway, so can't just be loosened and backed off a bit. Is this a normal situation, or is there another adjusting place? Many thanks, Robert
    Peoria, IL
    106
    Here is a pic of where mine sits when the engine is off. Also, here is the governor adjusting procedure from the operator's manual.
    Dave
    May 2012
    3
    Dave,
    Thanks a million.
    Rbt
