I would first check the Injector Pump Plungers (easy to do, just remove the cover plate) as mentioned before. You could also have a Valve sticking. Probably wouldn't be a bad idea to remove the valve cover and check for sticky valves. Give each valve stem a few drops of oil while you're at it too.
Rich Salvaggio
D2 5U9917
