Results 1 to 3 of 3
Thread: D23J moves and turns!!!!!
    Default D23J moves and turns!!!!!
    After eight months of off and work in the dirt, pulling engine, replacing flywheel, clutch, discs, brake,and shaft, water pump, radiator and not knowing if the steering clutches would work, it moves and steers and moved from where I was working on it across the creek and made it home! Not running great, bled injectors and #3 doesn't seem to be working. But it runs. Still alot of work needed, but happy. Many thanx to Acmoc and Jim Zimmerman, Karl, and Hector. steve
    d2, 2n, 8n, 4000, cub cadet 169, massey compact, home made tractor, and more
    Exact center of California
    Northern Victoria, Australia
    905
    Default Well done
    Thanks for the schnapps, great to see you are mobile and she turns, that's 99% of the battle won right there, that other cylinder should fire up pretty soon.
    regards
    Mike
    Dec 2008
    australia
    309
    Looks like it will be a handy tractor about the place .
