Results 1 to 8 of 8
Thread: Cat Technical info to print out from §wishy
    Australia
    280
    Thumbs up Cat Technical info to print out from §wishy
    OK guys
    I just found sum info burried deep in the Hardrive
    Could/Would B Printer Friendly
    <1>
    <2>
    <3>
    <4>
    <5>
    <6>
    <7>
    <8>
    <9>
    <10>
    Many thanks to Doug Sage from way back in 2004
    cya
    §wishy
    HasBeen
    - : ButEyeDoSt&2BCorrected : -
    Ifn U Get my Drift
    Feb 2007
    Mackay Nth Queensland
    45
    Swishy,
    G'day Mate, great stuff, keep up the good work.
    Macca,
    _____________________________________________
    1937 RD4 4G7002
    1959 D4 30A146/7U42539
    1958 No 212 Grader 95C 74
    195? D8 2U16568
    7,047
    Hi Swishy & edb,
    That's a delayed action for sure
    Yes, there are some boo boo's in the grader list.
    For now let's just sit on the info.....that's a winter project for me anyway
    Also looks like there may be a breakthrough on setting up archives
    Lee, George, Joe and myself are scheduled for a conference call Tues. the 28th to see what's required and what can be done. Standby........definitely could use some of your services. When it gets there will be looking for ideas on how to lay stuff out and present it along with categories for the topics we discussed some time ago.
    PS My wireless connection service is having some problems so my posts might be a little spotty
    Australia
    280
    Thumbs up
    OlMag
    GuddayM8
    RE:setting up archives
    When U have the PowWow with others on the subject on the 28th
    U need to determine what format to use
    as some don't have pdf. format on the computer
    Best to use WYSIWYG (WhatYouSeeIsWhatYouGet)
    I'm able to help an assist if you need the format done as a pic (as Above)
    available in jpg. bmp. gif.
    to be printer friendly i make each page 1100 x 800 pixels wide (landscape)
    or 800 x1100 pixels (Portrait) view to suit the A4 size paper
    a few have problems in printing this format out, but mainly due to the print setup & configuration
    I have over a 1000 pix (mainly as jpg.) in a few albums stored on a host site
    I use Imageshack but am not 100% happy useing there site as I have lost a few pics there n can only edit an album if I pay or start reinstalling again from the 1st pic
    Just my 2 cents worth from the udder side of the world
    LOL
    cya
    §wishy
    HasBeen
    Ifn U Get my Drift
    7,047
    Hi swishy,
    Got a couple of questions for you
    As you well know the archives could run into 1000's of pages and doing them all in jpg would be a big pain. The beauty of the pdf format is that you can load both pictures and text without having to scan every single page. At least that's my take
    Also I'm thinking more of an ACMOC storage than the photohost operations even though the freebee thing is attractive (up to a point)....also recall photobucket being more file access oriented than imageshack if we must go there. Still it seems to me the club ought to own the material and its storage/access. What's your take on file transfer if it should start out on a photo host and later be transfered to an ACMOC file......could be major issues of file size where everything would have to be resized.......bad.
    Australia
    280
    Thumbs up
    OlMag
    GuddayM8
    U raise a cupla good points
    Re:the archives could run into 1000's of pages
    Q: Is all the info stored on paper as in service bulletins etc ready to scan or is it already setup as a PDF file, or even on a fiche film?
    When U scan a page to pdf file it can misread some letters etc as seen when hitn on Google Patent some aren't perfect in translation
    the advantage of scanning to a PDF file: is just about anyone could do it
    Scanning as a jpg (Picture file) spose there ain't many th@ can or R willing to do it other than me on a limited basis
    scanning as a jpg I can alter n change parts of document th@ have aged and are not 100% readable I can Sharpen or lighten them up to makem readable or should I say more readable than the original. the other advantage is a jpg pic page is displayed as WUSIWYG where by a pdf is a file name to click on to retreive info
    Q: do U see th@ the pages @ Old Magnets Caterpillar Tractor Operation & Restoration Files an advantage or disadvantage being able to view each page up front??
    cya
    §wishy
    HasBeen
    Ifn U Get my Drift
    7,047
    Hi swishy,
    I will start a new post under "Archives"
    Kaukauna, WI
    222
    Swishy,
    Thanks for posting these documents!
    Always appreciate your talent and knowledge!
    Pat in WI
  1. Posting out-of-print ACMOC magazines here
    By gwhdiesel75 in forum DISCUSSION
    Last Post: 12-14-2007, 05:47 PM
  2. Great New Technical Term
    By NZCat in forum DISCUSSION
    Last Post: 05-10-2007, 01:05 PM
  3. Searching for technical manuals on modern D9
    By fiatad5 in forum DISCUSSION
    Last Post: 02-04-2007, 05:07 AM
  4. FREE Cat D2 from §wishy
    By §wishy in forum DISCUSSION
    Last Post: 01-10-2007, 03:29 AM
  5. FREE Cat SIXTY from §wishy
    Last Post: 01-02-2007, 03:50 AM
