Thread: Magneto Shaft Breakage & F/wheel Nut Torque
    victoria australia
    1,180
    Default Magneto Shaft Breakage & F/wheel Nut Torque
    Hi Team,
    there was some discussion recently on the correct torque for horizontal pony flywheel retaining nuts, this article from a Serv. Mag. 14 August 1953 covers Mag. Shaft breakage due to a loose flywheel and goes on to give a recommended torque for the retaining nut.
    7,112
    Hi edb,
    Good piece of obscure information.........thanks for posting.
    Along with that is an old service letter (little tough to read) describing the acknowledged fact that there could be manufacturing tolerance interference resulting in broken shafts and gears.
    Mar 2007
    Richmond Hill Ontario
    604
    Another thing to watch is the mag coupling nut on the end of the mag shaft. Saw one get loose and force the mag drive gear back and break the casting that holds the drive gear support bushing.
    Later Bob
  1. D4 7U broken Magneto shaft
    By cubpilot in forum DISCUSSION
    Last Post: 12-28-2009, 10:31 AM
  2. Torque spec for injector hold down nut and glow plugs
    By power stroke 99 in forum DISCUSSION
    Last Post: 10-08-2009, 05:27 AM
  3. Cat 30 Head Nut Torque / Tighten Sequence
    By Dale Rainwater in forum DISCUSSION
    Last Post: 05-25-2009, 08:31 PM
  4. Torque setting pony flywheel nut
    By Dozerman51 in forum DISCUSSION
    Last Post: 07-20-2008, 11:12 AM
  5. Replies: 22
    Last Post: 03-05-2007, 03:26 AM
