Thread: TEN with loader
    Kaukauna, WI
    222
    Default TEN with loader
    Not to be outdone by Willie....
    Just kidding!
    But I did come across this little TEN with a front end loader. It hasn't run in 8 years but is leaking oil from all the right places. The equalizer spring was removed and a fabricated, solid bar was installed in it's place. Has a broken radiator upright support on the right side. Engine is loose and it has an electric starter that is chain driven to the pto shaft! Hydraulic pump is mounted up front. Tight quarters in the operators area, and can you say blind spots! Original carb but wrong magneto. Has two of three brass tags on rear. Serial number looks like PT 473
    Waiting on a price.
    Pat in WI
    Napa Valley - Newville CA
    836
    Pat; That looks close but no cigar I think mine has more stuff on it LOL, I would call the stuff what it really is but they guy that built it was very proud of it. Also mine has right mag and runs but my chaindrive starter use crank spot it has chev alt. ,chaindrive pump on leftside, battrey on the fender powerwagon grill with a unique system, has 2 contrl valves push or pull both at same time it raises and lowers even or push 1 at a time it lowers that side only, probably the first hyd tilt ever built LOL. But if you want ill send you all the accesories when i cut them off then you could jump right into the dirt moven bizz. If anybody ever went to vista show and saw it in the parades the guy had wiskers and catface painted on the dozerblade and a big tail that came up from the drawbar and it will be in many more parades but look nake next to what it did in its last. Oh whats you address so UPS can del. the goodies
    Cumberland Wi
    245
    Blind Spots ?? I would think you could see the horizon and beyond from that Porch swing seat. lol
    Matt
    Kaukauna, WI
    222
    Willie,
    Thanks for the offer, but it looks like I'll have my own pile of "stuff" if this deal goes through. You're latest find does have lots of sheetmetal yet. I looked around in this shed to see if anything was laying around. Mostly old Ford and Ferguson parts.
    The magneto on this one is an Eiseman, just not a GV-4. Not many of these old Cats laying aroung here on the east coast. I find it pretty amazing that folks took the time to fabricate what ever device they wanted to install on these tractors. All in all, the loader was a pretty nice job.
    Good Luck with yours sir!
    Pat in WI
    Kaukauna, WI
    222
    Matt,
    I think the swing will cost extra! There were lots of extras piled or stacked on and around this tractor. Almost hard to see when you walked up to the shed.
    There is a nice Allis Chalmers model G parked near this TEN. Would love to have it too but someone has already inquired about it.
    Pat in WI
  1. d4 with overshot loader...
    By mickeymouse in forum DISCUSSION
    Last Post: 05-15-2013, 02:49 PM
  2. D2-5U Trackson Loader
    By drujinin in forum DISCUSSION
    Last Post: 10-05-2009, 02:37 PM
  3. New old Cat loader
    By tw in forum DISCUSSION
    Last Post: 10-27-2007, 05:01 PM
  4. 930 loader
    By D4Doug in forum DISCUSSION
    Last Post: 08-08-2007, 06:14 PM
  5. D2 with Trackson loader
    By mkreh23 in forum DISCUSSION
    Last Post: 05-02-2007, 07:58 PM
