Results 1 to 7 of 7
Thread: pony specs
    Aug 2007
    sebastopol, calif
    23
    Default pony specs
    Does anybody know the specs on a D47J pony, cubic inches and horse power? Also, where can I access some info on rebuilding and assembly specs?
    Default D4 Start.Engine
    The bore is 2.750" & the stroke is 3" so to get the cu. in. use pi (3.1416) & multiply by the radius squared 1.375" for the bore & multiply by the stroke 3" then by two for two cylinders.I haven,t any HP specs but someone might have a manual to gve you more tips. They aren,t too complicated to work on. Valves get set .007" to 010" clearance cold.Crank (std.) is 1.812" on mains & 1.750" for rod journals.
    7,046
    The pony motor (D2's &D4's) are rated 10 hp @ 3,000 rpm.
    Best source for specs and instructions are the Servicemens Reference Manuals for the various engines. For the D4 either the D4400 or D315 engines.
    victoria australia
    1,162
    Default J series D4 Pony Specs.
    Hi Team,
    scans below from the SRB, form 7490B, 11-43.
    Aug 2007
    sebastopol, calif
    23
    Default pony info
    Thanks for the helpful tech specs! At this point I am searching for rod bearings, .010, but may need .020 depending on what crankshaft ends up at. Std. rings seem to be no big problem. Would replace mains if I could locate some. Do you know of any sources for these pony parts ?? Bob
    McBEE, SC
    407
    Sure, try Cat!
    Sebastopol, Ca
    37
    Give Florin Tractor in Sacramento a try, they have a good stock of ner parts for the old Cats
  1. D2 grouser pad specs
    By silverstreak in forum DISCUSSION
    Last Post: 12-19-2009, 09:11 PM
  2. D4-D Specs
    By mtgstuber in forum DISCUSSION
    Last Post: 09-26-2009, 02:46 PM
  3. deisel 35 pony bearing specs?
    By miked238 in forum DISCUSSION
    Last Post: 04-13-2009, 06:23 PM
  4. Two Ton Track Specs
    By WILLSY/AUS in forum DISCUSSION
    Last Post: 09-25-2008, 04:30 PM
  5. D4 Idler specs
    By d23j in forum DISCUSSION
    Last Post: 03-28-2007, 06:59 PM
