I noticed in another post that some D8's had the clutch main plate fiber links switched to push instead of pull is there any known changes to the D6 since I have the clutch completly apart it would be the time to switch. If was to switch it looks like you would have to turn the main plate around due to the location of the grease zert.
Does make a person wounder if pushing would hold up better seems like less stress on links but maybe they would try to belly out in the middle?
Russell
