Thread: LaPlant Choate hydraulic pressure
    4
    Default LaPlant Choate hydraulic pressure
    I want to replace the pressure gage on my LaPlant Choate bulldozer on a D4-7U, 1950. The dial on the gage is rusted so I can't see the pressure range. What is the normal supply pressure I should see so I can get a gage with an appropriate scale?
    The model # for the LaPlant Choate hardware is 4BX-1385R, probably original with the tractor.
    central IL
    33
    I'm not sure about you make but the Cat 44 hyd pump would be at 1000psi operating press and 1200 relief setting. So I would guess a 1500psi gauge or bigger to be safe.
    Muzz
  1. Hydraulic Ram Pressure
    By oldparker in forum DISCUSSION
    Last Post: 10-16-2009, 09:58 PM
  2. Replies: 4
    Last Post: 09-27-2009, 09:36 AM
  3. Laplant Choate Hyd. Pump??
    By quinq in forum DISCUSSION
    Last Post: 08-06-2009, 09:07 AM
  4. LaPLANT-CHOATE
    By pdiesel in forum DISCUSSION
    Last Post: 03-15-2009, 09:16 AM
  5. Hydraulic Pump Pressure
    By First Cat in forum DISCUSSION
    Last Post: 08-16-2007, 10:14 PM
