Results 1 to 4 of 4
Thread: Single Cylinder D4
    Sep 2007
    Chino Hills, CA
    270
    Question Single Cylinder D4
    I tried to get the D4 running today, no luck. This D4 has a rebuilt head and new injectors and fuel filter but has not run in about 4 years.
    The pony is bad so we drug it with a wheel tractor for about a half mile. I had already checked the fuel supply to the lift pump and filled the tank.
    While in 4th gear, comp open, I bled the filter and had a good squirt of fuel coming from the bleeders behind the injection pumps. Now with comp closed I'm only getting fuel to one injector. I have tried various combinations of throttle open/closed, injector lines open/closed but three remain dry. It's a warm day and the head was hot from all the dragging and the one firing cylinder, so cold is not an issue. The engine will run on a shot of either.
    What am I missing?
    Carl Sharp
    Chino Hills, CA
    2xPV15; 3x22 2F; D2 4U; D2 5U; D4 5T; JD Model D; Ford 8N; Various other oddball stuff
    Vids: http://www.youtube.com/profile?user=carl4043
    Please visit my Ebay Store, Vintage Rust & Relics
    http://stores.shop.ebay.com/Vintage-Rust-and-Relics
    Feb 2007
    Mackay Nth Queensland
    45
    G'day Carl,
    had the same problem the the 4g, it was running on 2 pots only. When I pulled the injection pump down I found that 2 of the injector plungers were seized in the barrel. pulled it all down and cleaned it out.
    May pay to pull all your injectors lines off the top of the fuel pumps and do your drag start again to see if the all the pumps are "spitting", if they aren't you will have to pull the fuel pump down and clean it out.
    But it may just need more bleeding.
    Macca,
    _____________________________________________
    1937 RD4 4G7002
    1959 D4 30A146/7U42539
    1958 No 212 Grader 95C 74
    195? D8 2U16568
    7,113
    Take the side cover off the fuel injection pump housing and check to see which lifters are stuck. Sometimes you can free them up with your favorite penetrant
    and a little prying.
    Plains of NW Kansas
    305
    I think OM has the right idea. We had to do that on my neighbors D46U after it had set about 5 years. A little kroil and the next day they popped loose. Use a little Kroil and a lot of patience.
    D4Jim
  1. D4 hydraulic cylinder question
    By B4D2 in forum DISCUSSION
    Last Post: 04-15-2010, 08:36 AM
  2. D8 2U tilt cylinder
    By diablo in forum DISCUSSION
    Last Post: 11-18-2009, 03:44 PM
  3. Replies: 4
    Last Post: 09-27-2009, 09:36 AM
  4. D6 Rollers Double and Single
    By Paul Georgiou in forum DISCUSSION
    Last Post: 11-12-2008, 02:59 PM
  5. single act to dbl action
    By Stonestacker in forum DISCUSSION
    Last Post: 03-16-2008, 07:33 AM
