Thread: D2 pony motor magneto
    Nov 2007
    New Zealand
    Default D2 pony motor magneto
    I did a quick search, but didnt come up with anything..
    I'm currently getting a D2-5U going for my father, it's been sitting on a farm for the last 6 years. I've been told it was running when they parked it, but we've all heard that one before...
    It's a simple question i would've thought, but how do i get the rotor off the magneto? im used to working on cars, and the amount of force im using to lever the rotor off seems way too much. have i missed something?
    cheers.
    Sep 2007
    San Leandro, CA
    26
    I just had surgery done on mine. Does yours have a spark? If not it needs attention. I ended up needing a new coil, points and condensor. The rotor disc assembly should come off with little effort. Try a bit of kroil on the back and apply rocking pressure as you pull it. The whole assembly comes apart pretty easy. Also, the magnets in the rotor can be re-gaussed. Not sure where to go in NZ, but there is a place in Watsonville, CA that did mine a few weeks ago. Starts on the first pull now! Post a picture if you still have trouble.
    Feb 2007
    Madison Indiana
    4
    I have had the mag on my D2 loose a spark. So I made a bracket to fit the rope pulley and use a right angle drill to spin the motor. Pull the plugs first, and spin it until the mag generates a field again. It will take alittle bit of time and then you will see one spark then 2 then 6 then back it comes to life.
    good luck
    BDF
  1. RD-6/D6 pony motor help
    By Sasquatch in forum DISCUSSION
    Last Post: 09-29-2017, 07:35 PM
  2. D4 Magneto timing to Pony
    By auscuscus in forum DISCUSSION
    Last Post: 02-28-2013, 05:44 PM
  3. D4 magneto timing to Pony
    Last Post: 11-06-2009, 05:17 PM
  4. Timing Pony Magneto To Engine?
    By grit03 in forum DISCUSSION
    Last Post: 11-05-2009, 06:30 AM
  5. magneto problem cat d4 pony
    By gur in forum DISCUSSION
    Last Post: 05-30-2007, 02:58 PM
