Results 1 to 10 of 15
Thread: 17a with glow plugs?
    Mar 2007
    oklahoma
    50
    Default 17a with glow plugs?
    i looked at a 17a a couple of years ago a man had installed glow plugs on, didnt pay a lot of attention to how he did but i know they worked. Anyone know what parts or the procedure involed?
    7,048
    My after market interchange book shows the same pre-com chambers (non-glowplug) part # 2P483 to be used in D7 & D8 units designated
    17A,47A,48A,14A,15A,35A,36A1-5328,46A1-24432.
    I looked up the direct start attachment list for a D7 47A (effective 47A 3678)
    and it indicates a #5L6940 glow plug chamber.
    The number probably has been superseded but it's a place to start
    Mar 2007
    oklahoma
    50
    thanks for the info old magnet.
    Oct 2007
    Alabama
    98
    Default 17A Glow Plugs
    Old magnet, & dan
    I have 2 17 A,s one has been converted to direct start it is D7C early model and the other is a later model D7D with Pony motor. This winter I have been putting the D7D back in shap. I rebuilt the carb on the Pony and tuned the mag. Now it fires nicely.with the Pony no matter how cold I can spin the big engine till warms up then it start easily.
    With the direct start D7C it sure takes time to warm up drain the batteries etc.
    I would be nice to put glow plugs off D7 E . IN fact i would like to add a turbo on it as well
    Mar 2007
    oklahoma
    50
    Default 17a glow plugs
    yes Ali it sure needs them with direct start,even when you us the 24v starter, i dont know what you have to get or change to put them in, i figured someone on here would thow. a pony motor is the only way to go on those old cats, even if you have to rebuild them. anyone whose ever run one out of diesel with direct start will probably agree.
    7,048
    If your going to convert to direct start, do the whole job including the hand priming pump and glow plugs. No way your going to run on the starter to bleed the system on that sized engine. At least not without spare batteries or lots of recharges.
    Oct 2007
    Alabama
    98
    1- What do you have to do to put glow plugs.
    2- can you adopt hand priming pump to the 17 A
    Here is a trick for everyone to use for bleeding a system without Pony or extra batteries.
    1- take an old tire tube and cut out a big enough area or the rubber areound that air Valve stem
    2-Mounted this cut out rubber with the air valve stem on fuel tank and use big hose clamp to make sure it air tight on the fule tank
    3- Fill the fuel tank with air enough pressure to push the fuel out
    4- start the bledding process .
    It works
    7,048
    Hi Ali,
    Basically you need to get the direct start items that came with the D7E option
    including the glow plug chambers, glow plugs, wiring, switches and priming pump and the 24v generator or alternator if you haven't already got one.
    Mar 2007
    oklahoma
    50
    Default glow plugs
    i have the 24v generator, or its stamped 24v so are the 7e glow plugs 24v or 12v? 7e glow plugs are what you use in the 17a, also the 7e primer pump?
    7,048
    The glow plugs are 24v Part # 4S7824
    The glow plug pre-combustion chambers could come from any of the above listed models if they have them otherwise look for part # 5L6940 or possibly a 8S7601.
    The D7E 47A effective sr. no. 3678 with direct electric start would have all the parts for change over including the priming pump.
    The D7E 48A effective sr. no. 6883 with direct electric start would have all the
    It is not required to change to the straight tooth flywheel ring gear and drive if you use the helical drive option for starter conversion.
    There are other priming pumps (different model tractors) that could be used and have a simpler mounting and plumbing, like the through the dash models.
    Hope this helps..........or probably confuses
  1. How to test glow plugs
    By bcwayne in forum DISCUSSION
    Last Post: 04-15-2010, 11:03 AM
  2. Torque spec for injector hold down nut and glow plugs
    By power stroke 99 in forum DISCUSSION
    Last Post: 10-08-2009, 05:27 AM
  3. Glow plug voltage ?
    By yohan in forum DISCUSSION
    Last Post: 07-21-2009, 07:40 PM
  4. Start/heat switch&glow plugs
    By poor farmer/logger in forum DISCUSSION
    Last Post: 04-13-2009, 08:28 PM
  5. Direct start Pre-cup with broken glow-plugs
    By Dunefanatic in forum DISCUSSION
    Last Post: 01-05-2008, 05:59 PM
