Thread: pony motor head bolt torq spec
    Nov 2007
    pennsylvania
    5
    Default pony motor head bolt torq spec
    Can any tell me the spec for head bolts on a pony motor on a 318 cat, is there any order i should torque them in also? thank you.
    There is no specific order for tightening....just use standard torque value for the size of fastener.
    victoria australia
    1,162
    Default Torque Sequence
    Hi Team,
    here is are some scans from my tension wrench booklet showing generic sequences etc.
    Generally start in the center and spiral outwards, I like to come up to full torque in three steps and a further run around at full torque just to be sure.
    Also retorque after first run up when hot and again after 5 or 6 starts, the old copper asbestos gaskets shrink away after a while and start to leak.
    Hope this helps.
  1. Head bolt torq spec
    By hicrop10 in forum DISCUSSION
    Last Post: 03-12-2009, 04:52 AM
  2. D64r pony motor head torques???
    By denjoe in forum DISCUSSION
    Last Post: 05-10-2008, 04:49 AM
  3. Cat 10 head bolt torq.
    Last Post: 04-16-2008, 06:10 AM
  4. Diesel 35 pony motor head gasket
    By phill14504 in forum DISCUSSION
    Last Post: 02-03-2008, 08:59 PM
  5. pony motor head torque
    By RABBIT2 in forum DISCUSSION
    Last Post: 07-11-2007, 02:50 PM
