Results 1 to 6 of 6
Thread: One Hot Cat!
    Nov 2007
    NW Ohio
    495
    Default One Hot Cat!
    Taken from L.A. County Cal. website. Also shows "Tractor 2" from the show Emergency, "Snake bite", Great action shots of a D8H. The series is on dvd at stores.
    San Luis Obispo,CA.
    82
    La County most likely still has those animals, I saw one of them on the day fire in 06, still set up he same with a swamper seat and drop down curtians, no thanks, not with todays tractors and enviromental cabs out there.
    Seaside, CA
    96
    Yes, but that looks like a thrill that a roller coaster cant give you. I have always wanted to do fire dozing but never had the time in the seat that one would need to get certified.
    Karl
    Nov 2007
    Providence NC
    65
    Default fire dozer
    Even out east the fire dozers do not have enclosed cabs.
    I suspect that the heat would blow out the glass and burn up the window seals. Probably tough on everything.. too much heat..
    I also suspect that if they were to get a water drop near by that would be another way the glass would/could get blow out.
    Another reason may be safety. insulated environmental cab. operator may get a bit too brazen for his/her own good. Open cab, when he/she gets hot they would know to back off some. They can't save every stick of wood.
    Cheers
    Dudley
    D2
    Stuck Left Clutch, Dang
    San Luis Obispo,CA.
    82
    Yeah the rubbers can melt in the cabs and the glass cook a bit, but when you get in a bad spot, your better off with the cab than not, the guys with the open cabs get in the enviromental cabs when the fire hits the fan.
    Germany
    22
    Actually I've seen pictures of modern D8Rs with glassed cab.
    Is the D8 the biggest tractor in fire fighting service? Saying that I guess, that if necessary, you would call contractors with other/bigger equipment to help.
  1. Cat 30 getting hot!
    By chriscokid in forum DISCUSSION
    Last Post: 11-13-2009, 04:00 PM
  2. Cat 10 Missing when hot
    By archdf in forum DISCUSSION
    Last Post: 05-27-2009, 12:02 PM
  3. D8K running hot
    By paul.walpole in forum DISCUSSION
    Last Post: 02-02-2009, 04:48 AM
  4. D4 running hot
    By steamroller in forum DISCUSSION
    Last Post: 09-17-2008, 07:30 PM
  5. D8 Drives Poorly When Hot
    By hb11 in forum DISCUSSION
    Last Post: 03-11-2007, 07:07 AM
