Results 1 to 10 of 10
Thread: Almost ready to dirve
    ripley ny i4775
    81
    Default Almost ready to dirve
    Its been 2 years in the works but the high wide small 15 proto type is closer to being ready to drive out of the shop. I want to beef up the spring first but here are some pictures of how it is coming.
    Pictures 1, 2, and 3 were taken tonight. The fourth is how it looked when it came home 2 years ago.
    Central Coast of California
    291
    That is some beautiful work. Congratulations on bringing a rare piece of Caterpillar history back to life. Don
    Kaukauna, WI
    222
    Very Nice Ron,
    I know when you start a project like that, you never think it will ever get finished. Then one day you look up and sitting square in front of you is a work of art like no other. I'm sure you are looking forward to the day when you walk it outside for the first time.
    Thanks for keeping us posted on your progress.
    Pat in WI
    Western Cincinnati, OH, USA
    237
    Ron,
    I'm going to keep those photos for inspiration when I hit some tough spots. Good Job! Be rightfully proud of it.
    AL
    D2-5U-10614
    other small excavating pieces as well.
    1,588
    What a difference all your hard work made! So nice to see a tractor come to life. GWH
    Palmer, KS
    192
    Great job, that will be a tremendous asset to your collection and everywhere it is displayed.
    Jim
    Pittsburgh,PA
    310
    Ron, How does the two (original) angle supports work under seat? Or was there some kind of special bracket made up? Also why doesn't it use HC inner fenders? I thought I made a set for that tractor. Steve
    ripley ny i4775
    81
    Default fenders
    steve , when I started it looked like it needed high type inner fenders, but when it came time to fit things up the hc pieces didn't fit and reg assy fit and all the bolt holes line up perfect including the angle braces at the back, there are mounting holes in the spacers. This tractor should inspire some people
    that have projects that are maybe worth restoring to just do it
    THIS WAS IN PRETTY BAD SHAPE AND IT WILL BE NEAR TO PERFECT WHEN DONE. It will have nos undercarriage and front idlers and near to new tracks and pads and sprockets . The engine and clutches are all completley
    renewed as well as the transmission and final drives. Every single part has been apart and cleaned inspected and replaced if any wear was detected
    All new hoses and belts, gas tank bottom replaced and tank sealed , Radiator
    completely dissambled and cleaned one tube at a time. and reassembled with new gaskets and radiator guard completely rebuilt with stainless metal. New seat cushions by hahn, and many other new parts.
    Special thanks to Steve weaver, Pat nc, Don Martin , Dias Spring, Jim Zimmerman , Jeff Moyle ,John Hahn ,Melvin Rust, and anyone else that helped in anyway to complete this project. Ron Meeder
    Lansing,Mi suburbs
    520
    Great work Ron, It surley inspires me. I did talk to Bob regarding the part I was looking for and the cover you needed, He was going to take a look for both of them. Keep up the great work.
    KINGDOM lynn lake manitoba
    647
    excellent job, i looked at the pictures and realised that i HIGH machine is a lot harder to work on then a normal machine.
    glad you are gtting close to enjoying the fruits of your labour.
    thansk
    Cat Trains for ever or until the snow melts
    www.kingofobsolete.ca
    www.cattraintours.ca
  1. D6 ready to work
    By brialin in forum DISCUSSION
    Last Post: 08-11-2009, 11:11 PM
  2. Another one ready for the road
    By Willie in forum DISCUSSION
    Last Post: 02-29-2008, 06:30 AM
  3. The 8R Is Almost Ready To Come Home
    By JC 4T in forum DISCUSSION
    Last Post: 08-27-2007, 04:27 AM
  4. Ready to move in
    Last Post: 05-20-2007, 10:36 AM
  5. Getting 7C 15 ready for show
    By Firecat in forum DISCUSSION
    Last Post: 03-17-2007, 02:55 PM
