Results 1 to 4 of 4
Thread: d4 6u starter pinion
    Mar 2008
    california
    2
    Default d4 6u starter pinion
    Having a hell of a time with this. Raised the starter, engaged the pinion, took the governor cover off, took the clutch cover off, I can get the whole assembly out to the point that if I could achieve a sixteenth of an inch more I would be able to get it past the governor. The barring in the middle of the clutch/pinion shaft has broke on the race, which is the reason for removol. I have also removed the inspection plate below the main pistons. Still I can't get clearance.
    Anyone ever dealt with this and have a success story? any ideas hints would be greatly appreciated Thanks
    7,049
    Try rotating the pinion so the latch dogs are not interfering with that last 1/16 in. Fit is tight but does work for removal. You've covered all the normal stuff.
    Patience
    Mar 2008
    california
    2
    I'm trying to have patience. It just doesn't seem that I can get any more rotation out of this thing. It sounds like you have some experience with this procedure. I don't know if you'd be available to take a look at it. I'm located in soquel.
    7,049
    Yes, I can do that, your not very far away. Send me a PM address and time that would work.
  1. D2 starter pinion removal
    By D2Dave in forum DISCUSSION
    Last Post: 03-24-2012, 08:06 PM
  2. D42T Starter Pinion
    By bernie in forum DISCUSSION
    Last Post: 10-15-2009, 11:43 AM
  3. D2 starter pinion removal (again)
    Last Post: 10-15-2009, 09:02 AM
  4. D2 Starter Clutch and Pinion
    By novavalleycat in forum DISCUSSION
    Last Post: 09-30-2009, 07:23 PM
  5. Starter Clutch and Pinion
    Last Post: 08-25-2008, 12:09 PM
