Results 1 to 10 of 16
Thread: New member
    Mar 2008
    Oregon
    13
    Default New member
    hi, all I just signed up and became a member.
    I have a 5j D2 that I got not long a go. I am not much of a mechanic so i might be asking for a lot of help in the near future. Thanks for letting me join your group.
    1,588
    Welcome aboard Slurrydog! I have a D25U, and not a mechanic, so I understand. GWH
    Sep 2007
    Chino Hills, CA
    270
    Default Welcome
    Hey Slurry lots of good info here and real helpful folks, they have helped me more times then they know. I would suggest using the search function on the above toolbar before posting, as new owners usually have similar questions, and they have been answered many times over.
    Also there is a D2 registry at http://www.antiquecaterpillar.net where you can see who has the s/n near yours, who is nearby and what options are out there.
    I bought my first Cat in late 2007 and currently have 8 so be forewarned the virus you have exposed yourself to...
    Carl Sharp
    Chino Hills, CA
    2xPV15; 3x22 2F; D2 4U; D2 5U; D4 5T; JD Model D; Ford 8N; Various other oddball stuff
    Vids: http://www.youtube.com/profile?user=carl4043
    Please visit my Ebay Store, Vintage Rust & Relics
    http://stores.shop.ebay.com/Vintage-Rust-and-Relics
    Mar 2008
    Oregon
    13
    Default thanks
    thanks for makeing me feel at home. I have always wanted a D2 since I was a boy, I know that sounds sick but I have, anyway I finally got one although it is not running right now I think with a little luck and the help of this group it will live again. So thank you again for makingme feel at home.
    177
    Welcome aboard,
    You've always wanted a D2. Well, there's no reason to stop at just one. Besides the series goes up to D11. The guys here will help you you do everything but pay for it.
    Good Luck
    Biggastractor
    As said above, Hood River county, Oregon.
    577
    Hi Slurrydog. Profile says you are in Oregon. Whereabouts? I am in Hood River and run a D2 5J. Let me know if you need a look at something.
    Jack
    Mar 2008
    Oregon
    13
    Default hi, jack
    hi, jack iam in Cottage Grove, 20 miles south of eugene. My d2 is not running yet, so I might have to ask for your advice every now and than,such as a good local parts source. Would love to hear about your d2.
    577
    'lo again,
    My D2 is an oldie but a goody. It was upgraded to D3 sealed rollers several years ago. I've had it since 1969 and have put a bunch of hours on it, though not so much any more. Right now I can't start it. The carburetor is dumping raw gas down in to the cylinders, probably something holding the float valve open. I've been having an absolute hell of a time with the present day gasoline. When I cleaned the filter I got one easy start out of it, but I suspect some of the varnish and crud went down the fuel line.
    They used to say "Leave the rig in storage with a full tank to minimumize evaporation. Don't do that now. Drain the tank and run the carb dry. Likewise, run the tank down to nothing before you gas it up again so the varnish doesn't accumulate. It's a different world we're living in now.
    I'll rerun a pic of the D2 running last snow storm, also my old D7 3T on a winch job last year.
    Jack
    Nov 2007
    Far Southwestern Iowa
    167
    If the carb has the old cork float coated with some black substance the 10% alcohol in the gas will soak through the black coating and penetrate the float. The float will sink. It takes a while for this to happen. The 87 octane fuel and a shot of Stabil is the best bet.
    Eastern Oregon
    966
    A cure for those old cork floats is to dry 'em out for a few days, then coat 'em with a good fiberglass epoxy. I did that to the float in my old D2 several years ago and it's still holding. Also running the pony out of gas instead of shutting 'em off with the off-on switch with those old cork floats is a good idea.
  1. new member
    By 64farmboy in forum DISCUSSION
    Last Post: 04-04-2010, 05:40 AM
  2. Hello from a new member
    By Radcam in forum DISCUSSION
    Last Post: 11-29-2008, 10:22 AM
  3. New member
    By sodbust in forum DISCUSSION
    Last Post: 12-23-2007, 06:35 PM
  4. New member
    By ozdicko in forum DISCUSSION
    Last Post: 11-07-2007, 12:18 AM
  5. New member with D4 2T
    By sherman in forum DISCUSSION
    Last Post: 12-28-2006, 03:10 PM
