Results 1 to 6 of 6
Thread: Cat thirty head gasket nut torque
    McBEE, SC
    2,390
    Default Cat thirty head gasket nut torque
    Does anyone have a good figure for the torque? I have seen some general charts, but thinking that these 3/4" old nuts/studs don't need the full torque of a modern engine.
    What would be sensible?
    D2 5u & 3J
    212 9T
    RD4
    D4 7J & 7U
    R4 4G
    Gas 35's
    Diesel 35
    Diesel 40
    Gas 50's 5A
    Diesel 50 1E1755
    Diesel 75
    D 8800 power unit 9J 6113SP
    LeTourneau D4 tournapull/Q Carryall
    Letourneau D Carryall's
    LaPlant-Choate CAB-97
    Apr 2007
    Pioneer Valley, Western MA
    263
    Stephen, I find that the settings Cat used years ago matched a grade 5 torque That is what I put on my 30 when I did it.
    Herb
    USA M2 5E3562SP
    McBEE, SC
    2,390
    Quote Originally Posted by HFDZL View Post
    Herb, do you recall what was that grade 5 torque figure ?
    D2 5u & 3J
    212 9T
    RD4
    D4 7J & 7U
    R4 4G
    Gas 35's
    Diesel 35
    Diesel 40
    Gas 50's 5A
    Diesel 50 1E1755
    Diesel 75
    Apr 2007
    263
    Here is the secret Cat specs 'Do not divulge to mere mortals that do not own Caterpillar !!!'
    The second list is the Cat one, the first is general torque settings
    Herb
    USA M2 5E3562SP
    Nov 2007
    NW Ohio
    3,705
    That does not apply to all Cat bolts though! Later machines have different torques for certain applications. I just installed a track frame on a late 955L, the service manual called for 630 +- 50 ft lbs torque for the 7/8" bolts.
    McBEE, SC
    2,390
    Quote Originally Posted by Rome K/G View Post
    That is what I'm saying "horses for courses "
    D2 5u & 3J
    212 9T
    RD4
    D4 7J & 7U
    R4 4G
    Gas 35's
    Diesel 35
    Diesel 40
    Gas 50's 5A
    Diesel 50 1E1755
    Diesel 75
