Thread: 1930's 40's 50's D4 dozer eng questions
    Apr 2008
    Lexington, Ma.
    22
    Default 1930's 40's 50's D4 dozer eng questions
    This is my first day on this site as I have just ended up with a total of 2 complete and 3 partial machines. First the later engines of 4.5 bore vs. the early of 4.25 bore - do they use the same bottom end? The later engines have the decompression lever on the valve cover vs. on the 4 individaul cam follower plates. Also is there any call in this group for the older parts ? Thanks Jim
    Plains of NW Kansas
    305
    Gosh Jim, for a minute I thougth that was JR Ewing!!
    If you have the serial numbers of the D-4's that would nail it down as to what engine they had. (If they were original) The serial number would be something like 7U 1789 on a plate on the side of the engine and on the rear of the tractor.
    D4Jim
    1,784
    No, bearings etc are different between the D4400 and D315 engines.
    If you can keep them, I expect you can move parts from any of them. The most important thing is how close you are to the one who needs the parts (at least if they're very heavy)!
  1. D2 5U specs for Diesel Eng Head
    By R4pat in forum DISCUSSION
    Last Post: 02-02-2009, 06:38 PM
  2. 2A Dozer
    By d4e in forum DISCUSSION
    Last Post: 12-25-2008, 09:07 PM
  3. where do i find serial # on 40's or 50's D7
    By jthompson0501 in forum DISCUSSION
    Last Post: 10-27-2007, 02:25 PM
  4. The New C@ Dozer
    By §wishy in forum DISCUSSION
    Last Post: 07-23-2007, 04:40 AM
  5. The Little Dozer that COULD
    By Bill Glenn in forum DISCUSSION
    Last Post: 12-27-2006, 05:23 PM
