Results 1 to 7 of 7
Thread: 22 Plug Wires
    Mar 2008
    florida
    32
    Default 22 Plug Wires
    Guys, Any Idea What And Where To Get The Right Plug Wires For My 22?, also the exhaust manifold is cracked and i was wondering if it will run like this it has a crack all the way around about 1/16th thick and also has a crack where it bolts to the intake any affect on the intake of the fuel? 1 more the fuel pump is missing the glass bowl and the previous owner has the line ran straight from the tank,, gravity fed any problems with it starving for fuel like this? needless to say i need some parts if any one has some they are willing to part with, thank you. frank
    United States
    25
    I've just been using the standard cloth covered plug wire that can be bought at most engine shows. Working OK. Most magneto shops should have some.
    Nov 2007
    Far Southwestern Iowa
    167
    NAPA usually can get a solid core wire, Packard 440. Magnetos require plain solid core wire and also non resistor plugs. The antique car, tractor, or engine places usually stock the solid core wire with a nice period cover on it if you want the original look.
    Malin Oregon
    137
    Morgan Hill, CA
    159
    Default plug wire
    solid core wire from napa - part #734803. 59 cents a foot last time I bought it. - Wally Terminals 727008 (4) 727006 (4) and 4 boots#727402
    Sep 2007
    Chino Hills, CA
    270
    Hey Brewser what about the boots?
    Mar 2008
    florida
    32
    thanks!, will hit napa this pm.
  1. R4 plug spec
    By kiwicats in forum DISCUSSION
    Last Post: 11-11-2009, 12:23 AM
  2. Spark Plug Wires
    By JasonPayneCrawlers in forum DISCUSSION
    Last Post: 03-26-2009, 06:38 AM
  3. Replacing Cat Ten Plug Wires
    By TomP-TX in forum DISCUSSION
    Last Post: 12-27-2008, 09:16 AM
  4. Plug wires for a Cat Ten
    By Member2103 in forum DISCUSSION
    Last Post: 07-03-2008, 01:38 PM
  5. plug?
    By bernie in forum DISCUSSION
    Last Post: 12-02-2006, 01:53 PM
