Results 1 to 4 of 4
Thread: Amount of cable on front CCU
    Oct 2018
    Upstate NY
    9
    Default Amount of cable on front CCU
    I have a 13A D8 with a front cable control unit. How many feet of cable should there be in total. There is a 3 sheave top and lower pulley?
    Thanks,
    Nathan M
    15,399
    Closest I could find was 72 Ft 1/2" 6 x 19 Right Lang Lay for a 6 part line on a #30 CCU
    For a #24 CCU the drum capacity is 75 ft so I would say get the 75 ft.
    Apr 2012
    Moose Lake, MN, USA
    3,621
    Quote Originally Posted by Nathan M View Post
    Thanks,
    Nathan M
    The old timers used to put extra cable on and keep the drum mostly empty. The extra cable was kept beyond the wedge and looped up and tied to the right front sweep or that area. Then when the cable got badly frayed you could just cut a few feet off the drum end and pull a bit more off the loop. Saved a lot of cable that way.
    1937 Cat #11 tandem auto patrol,diesel, w/plow and wing, 6K506SP, 1937 RD 4 Ag Crawler RD5356, 1939 Cat 22 2F5429, 1952 Model 212 Grader 9T03427, 1953 2U D8 Dozer 2U20751, 1961 922A Rubber Tired Loader, 59A812, LeTouneau LS Cable Scraper, Cat/Lincoln 600 AMP Dual Welder, DW-21 Cat Scraper, DW-10 dump wagon/water wagon
    Sep 2011
    Western Kentucky
    62
    Default Front CCU
    Thanks,
    Nathan M
    Not really answering your question, but adding to the post. My dad had 3T D7 with a front CCU. He never bought any cable for his CCU. He took the good pieces of his colleague’s left over cable after retooling the rear CCU’s on two 14A D8’s. Dad had a Hyster D7N on his tractor’s Rear. He seldom charged to pull the D 8’s out of their hang ups. Free cable and occasional free lowboy transports were the norm. Dad charged $10/hr for dirt work and $12/hr for clearing in the 1950’s.
